recon dies on hills
Old Jan 28, 2007 | 09:48 AM
rodneygt's Avatar
Default recon dies on hills
My bro-n-law bought a used recon cheaply, probably around '02. It looks pretty good but has been well used, the engine seems tired and it smokes. Aside from that, when the bike is at angles of say 30 deg or steeper, the engine wants to die. He can keep it from dieing by pulling the choke but still has to baby it a bit to get it to plane out again when off of the incline. I've not fiddled with it but suggested the float level may be off in the carb. Before I look at it, I was wondering if anything else could cause this problem or if anyone had experienced something similar.
Thanks,
Rodney
Old Jan 28, 2007 | 11:02 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A good place to start is to clean the carb and adjust the float. The smoking probably means it is time to do the top end.
Old Jan 28, 2007 | 11:39 AM
haxwax's Avatar
sounds like the carb is full of trash
Old Jan 28, 2007 | 12:01 PM
deanz400's Avatar
had a motor that had a similar problem ,turned out it had a couple of small weed seeds that would clog the fuel flow,it was weird ,
Old Jan 28, 2007 | 09:22 PM
JLsparky7's Avatar
Does he have an aftermarket pipe or something on it? If so the owner might not of re-jetted properly. Do the easy stuff first though like the guys above reccomended.
Old Jan 29, 2007 | 03:31 PM
rodneygt's Avatar
Thanks for the replies. It's stock.
Rodney
Old Jan 29, 2007 | 10:29 PM
Bigake's Avatar
I had the same problem. Take the carb bowl off and check the little plastic round piece at bottom of bowl. Mine had came loose and was restricting fuel flow. When you put it back together be sure to put the bowl on with carb upside down.
Ake
pgamboa
Dec 24, 2023 11:52 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
