what oil for 2004 400ex?????
Old Jan 28, 2007 | 08:36 PM
godeep69's Avatar
Default what oil for 2004 400ex?????
How much oil and what kind of oil do I use for a 2004 honda 400ex? I just bought a used one and the owner always made it to the dealer, I would like to do it myself thanks
Old Jan 28, 2007 | 08:50 PM
haxwax's Avatar
Reconranger suggested using Maxima Extra oil to me so i gave it a try and it works great, it is a little more costly but it works great.
Old Jan 28, 2007 | 08:51 PM
JLsparky7's Avatar
I think I saw a thread that said 1.7 qts.
I run amsoil 0w40 in all my powersports toys and it works excellent. Heres a link. This stuff is amazing, works in motors, transmissions, wet clutches, cold weather, hot weather.....
https://www.amsoil.com/storefront/aff.aspx
Pay 10 bucks and you get everything at wholesale for 6 months. Just become a preferred customer.
Old Jan 28, 2007 | 10:16 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
I'd just run up to the honda dealer or any bike shop and get motorcycle oil, maybee even an auto parts store might have it, I use Mobil1 10-40 synthetic motorcycle oil, just remember NEVER USE CAR OIL (regular oil).
Old Jan 29, 2007 | 12:36 PM
oldturtle's Avatar
You have the right to spend $8.00 a quart as recommended above but your motor will not be any better off than spending $2.00 a quart for Shell Rotella T or Chevron Delo in 15-40 non synthetic. Now if you are going to make a habbit of starting and riding in below freezing temperatures then either of the above in full synthetic 5-40 will start easier and warm up quicker. This sport is expensive enough without dumping money down the oil recycler hole. With oil filter change my 400EX will take a little over 2 quarts.
Old Jan 29, 2007 | 01:29 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There was a post recently on how to do an oil change (volumes, what to drain, etc.). We went into some detail, and it has some real good info that might save you some grief. When I find it, I will post a link!
As for what oil to run: http://forums.atvconnection.com/mess...did/510867.cfm
Old Jan 29, 2007 | 06:59 PM
Ozark38's Avatar
Use regular ol dino oil (4 stroke motorcycle oil) if you like to powershift your 400EX. You can use synthetic oil but if you like to powershift alot (like while dragracing) you will get the slippy slips.........[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 29, 2007 | 08:38 PM
Coontis's Avatar
In regards to the Maxima oil, which weight do you prefer? Right now, I run a Mobile 1 synthetic 15W50. I was thinking of switching to Maxima and running the 10W in the colder months and the 15W in the summer months. Any thoughts or does it even matter? Thanks for the advice!
Old Jan 29, 2007 | 10:13 PM
Red Rider
Maxima's 10W40 Extra is a "light" 40. It is spec'd right on the border between 30 and 40, so you could also call it a "heavy" 30 if you like. I think of it as a "35".
Around here, the winters are mild (except for this year) and the summers are very hot, so I run 10W40 in winter and 15W50 in summer. In Ohio, I would run 10W40 in summer and probably 5W30 in winter. Maxima needs to come out with a 5W30 Extra, and maybe even a 0W30 for those in the really frozen north.
Old Jan 30, 2007 | 01:27 PM
Coontis's Avatar
Thanks for the info. I just found a dealer that sells maxima in the area so I will give it a try. Thanks again!
