fuel pump 87 foreman
Old Jan 30, 2007 | 10:57 AM
win's Avatar
win
Default fuel pump 87 foreman
Hi: new here. have figured out from former posts that my fuel pump took a dump on my ol 87 foreman. I have 5 volts in the wires leading to the fuel pump but the pump isn't working. Have looked up a replacement (gasp,$138.00). Has anyone tried a cheapo in line fuel pump from a auto supply store. Does anyone know what kind of pressure the original pump puts out. Any info would be appreciated. Am not going to spend that kind of money on this ol honda. thanx. wnk.
Old Jan 31, 2007 | 07:21 AM
win's Avatar
win
Hi: anyone help me out here. someone must have tried a aftermarket fuel pump on a honda. thanx win.
Old Jan 31, 2007 | 10:24 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Got to say that I was not aware that any Forman ever had a fuel pump! Why would it need one? Most quads fuel system is just a nice simple nothing to go wrong gravity feed. The first quad I ever owned that has a fuel pump, is my new 07 Honda 420 Rancher that has fuel injection.
Old Jan 31, 2007 | 06:31 PM
win's Avatar
win
these old foreman and four trax had the tank under the seat, lower than the carb so they needed a fuel pump. win
Old Jan 31, 2007 | 08:22 PM
rodeo999's Avatar
I would be concerned about the volume and pressure on a pump designed for a car. There might be an alternative by using a vacuum fuel pump. I saw this on a website could help http://roadstarclinic.com/content/view/107/96/
Contributed by Ted Kuchnicki (DocShadow)
A number of riders have made the change from the stock electrical pump to a vacuum pump. The vacuum pump is used in ultralights and snowmobiles, thus it is more than reliable for our bike applications. There are two pumps that have been used; the smaller Mikuni DF44-211 (14 L/h) and the larger Mikuni DF52-136 (31 L/h). See http://www.mikuni.com/pdf/fuel_pumps.pdf for pics of the various models and info. The larger pump has duel fuel outlets; for our application one of the outlets must be plugged.
Installation recommendations:
As the vacuum pulse decreases distance between the pump and the carburetor increases, the distance between these two should be minimized. I would recommend no longer than 1-foot for the smaller pump.
Use thick-walled tubing for the vacuum line in order to minimize collapse and maintain a strong pulse.
The vent should face down.
To minimize vapour lock, place the pump in an area where it is cooled.
The following details my installation:
First remove the original pump, bracket, fuel filter and lines.
On the vacuum pump, remove the 4 screws on top and replace with same size bolts (Figure 1). This is only important for this installation, as the screws cannot be removed to service the pump once the pump is in place.
Remove the manifold (I have a Nemesis).
On the Nemesis there is a flat spot corresponding to where the vacuum nipple is on the stock manifold (Figure 1). At this spot I drilled a hole through the manifold the same size as the inside diameter of the vacuum nipple on the pump.
NOTE: On the stock manifold: 1) the vacuum nipple on the pump must be removed; or 2) the vacuum nipple on the manifold must be removed; or 3) a short piece of rubber tubing could join the two nipples (test to see if this will fit when the manifold is mounted).
Enlarged the same hole by drilling with a bit just a little smaller than the outside diameter of the largest part of the vacuum nipple. All the nipples on the pump bulge out near the ends (Figure 2). DO NOT drill all the way through the manifold; drill only about ? of the way down the original hole.
Sand the bulge on the vacuum nipple on the pump until it fits snugly into the manifold. Do not over sand otherwise the fit will be loose.
Smear the vacuum nipple from the bulge back to the pump body with JB Weld, making sure to not to get any JB Weld from the bulge to the end of the nipple so that the hole in the nipple does not become blocked with JB Weld. Insert the nipple into manifold until it bottoms. Smooth any excess JB Weld around the nipple/manifold joint.
Orientate the pump as shown if Figure 2.
Install manifold on the bike (Figure 3). Note the close tolerances and proximity to the engine; however, there is airflow around the pump.
The original fuel filter can be used. I replaced it with a small clear snowmobile filter that has the same size inlet/outlet as the pump.
I used ?? fuel line for all connections rather than the stock 5/16?. It will be a tight fit to connect to the carburetor and petcock, but the smaller line does fit.
Connecting the fuel line to the pump inlet is also very difficult because of the tight quarters and awkward angle. I recommend the line be put on before the manifold is put into the engine.
Old Feb 1, 2007 | 01:18 AM
athlon450's Avatar
Pulse fuel pump and relay on ebay!
mtdewmn
Jan 19, 2017 12:13 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
Mikea1978
Jul 4, 2015 12:37 PM
