82/83 Honda Big Red
Old Mar 17, 2007 | 10:07 PM
janj205's Avatar
Default 82/83 Honda Big Red
Hello, I just bought a honda big red and right on top kinda by the pull start there is some kind of oil fill its capped by a big flat head srew. Its not the motor oil fill because thats on the other side with the little dip stick so can anyone tell me what goes in that one? Tranny oil maybe? Thanks!!!!!
Old Mar 17, 2007 | 11:00 PM
Madwolverine's Avatar
Nothing goes in there. That's the timing mark inspection hole. The flywheel and stator coil are in there.
Old Mar 18, 2007 | 07:13 PM
janj205's Avatar
Hey thanks, that makes sense now but what i couldnt figure out was that there was oil on the backside of that flat head plug
Old Mar 19, 2007 | 10:22 AM
There should not be oil in there. There is a seal between the inner case and the flywheel. Pull off the pull starter and take a closer look. If there is a good amount of oil in there you will want to get a flywheel puller, remove the flywheel, and replace the seal.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
