? on 2007 trxex400
Old Mar 21, 2007 | 07:56 PM
Tbone9's Avatar
Default ? on 2007 trxex400
I have been reading these forums and everyones saying change the oil after 3 hours of rideing. but the dealer told me to ride it until 5 tanks of gas or 20 hours bring it back for it most importment service.he never told me to change the oil that qiuck. does this matter or not and if so what kind of oil should i use. dealer told me 10w30and since its new should I change the oil filter also.
Old Mar 21, 2007 | 10:09 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.mototuneusa.com/break_in_secrets.htm
Some good basic oil info: http://www.thumperfaq.com/oil.htm
The idea of doing a very early oil and oil filter change is to get any metal shavings out of the engine right away that are left over from machining and newly meshing gears. Hondas do come very clean from the factory, but better to play it safe!
During break-in, you want to use a petroleum oil like Honda GN4 or Maxima Premium. I usually change mine for the first time at 1 hour, then again at 5 and 10 hours. After 10 hours, I consider it broken in and switch to Maxima Extra an ester synthetic oil (http://www.maximausa.com/technical/l...beNews2002.pdf).
Then do your first valve adjustment at 20 hours.
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
