New guy needs help
Old May 17, 2007 | 09:51 PM
hogtide's Avatar
Default New guy needs help
Hey guys, I'm new to the site and I figure this question has been answered a bunch allready, but I can't seem to find it in a search.
I parded my recon ES after deer season and it was doing great. I tried to get it going today and the battery was toast. Put the charger on it and couldn't get it to shift. No noise at all when I push either button. When I shift it manually, the light on the 1st gear blinks but no shift. Can someone tell me where to start looking for problems ? It will start and run just fine.
Thanks
Hogtide
Old May 17, 2007 | 11:55 PM
Gimpster's Avatar
If the battery is not fully charged, it will not shift well or at all. check your fuses.
Other than that, count the blinks on the dash. Most likely a bad shift angle sensor or connection.
----- Gregg -----
Old May 18, 2007 | 10:38 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Sounds like a dead cell in your battery.
Old May 18, 2007 | 11:11 AM
Fulltiltrider's Avatar
I agree, I have a friend that had the same problem and it was the sensor, not very expensive though
Old May 18, 2007 | 06:35 PM
hogtide's Avatar
Hey, thanks for the info. can someone tell me what a shift angle sensor looks like, and where it might be located ? I have checked all the connections that I have found in the wiring harness, I've even greased them, they all look good and bright except for the 15 amp fuse recepticle. I cleaned it up and greased it also.
The 15 amp fuse and the 30 amp fuse was NOT blown.
If someone could send me a a copy of a wiring schematic (diagram) of a 2003 250 ES Recon, I would be very greatfull. My daughter is driving me nuts to get it running.
I really appreciate all the good info you guys have given me.
Thanks,
hogtide
Old May 18, 2007 | 10:03 PM
Gimpster's Avatar
While setting on the unit, left side front lower engine. There is a tin shield covering it. The shield is kind of a pain to remove. This sensor is most likely the problem
----- Gregg -----
Old May 21, 2007 | 12:14 AM
hogtide's Avatar
Hey guys, Thanks a bunch, Gimpster was right on, the sensor was the culprit. I replaced it and I now have it back to throwing dirt and making a young girl very happy.
I really appreciate your advise and technical knowledge.
Thanks again,
Larry
