400EX Knocking
Old Jul 4, 2007 | 03:08 PM
hondarules666's Avatar
Default 400EX Knocking
<div class="FTQUOTE"><begin quote>Originally posted by: muddstudd
what octane of gas do you run in it?</end quote></div>
this guy knows what hes talkin bout
try a higher octane gas because i see that you have a piston in your machine if its a high compression piston then use a 91 or higher octane
Old Jul 4, 2007 | 04:20 PM
LaCountryGirl519's Avatar
I put 104 octane recently and never go below 91 but still there...
Old Jul 4, 2007 | 09:22 PM
muddstudd's Avatar
there are lots of things that can make an egine knock. changing the grade of gas is about the easiest thing to try first. if you've replaced all the timing components and adjusted all your valves it maybe time for a tear down of the topend. i've only seen it a couple of times on older motors (small block chevys) sometimes a peice of carbon from the combustion chamber comes loose and keeps getting hammered between the piston and combustion chamber. it sounds like a rod knocking only instead of coming from the bottom of the motor it comes from the head. i'd say tear it down, check all your clearences, and get a valve job.
Old Jul 4, 2007 | 09:50 PM
  #15
Yeah ^ That's what my dad said (connecting rod) and tear it down. I know fixing connecting rods is gonna be expensive but do yall know about how much?
Old Jul 5, 2007 | 01:41 AM
  #16
exrider91's Avatar
my 97 300ex started doing that after i took the engine out to fix a crack even with the ticking it still runs strong.i think its the values because it gets fastier as the rpms go up but after half way to peak rpms you cant hear it over the exhaust.
Old Jul 6, 2007 | 08:28 AM
  #17
kizmo's Avatar
i have a 88 350 honda 4 stroke 4x4 and had a bad ticking noise in it so i checked all the posibilities and ended up it was my cam and rockers that were allworned out ...just a thought that may help..
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
01ssls1
Sep 22, 2015 06:50 AM
