83 Honda Big Red 200
Old Sep 16, 2007 | 10:00 PM
mike828's Avatar
Default 83 Honda Big Red 200
I'm having a problem with my 3- Wheeler, the carburator is getting to much gas. If any of you have a diagram, I need the help.
Old Sep 16, 2007 | 10:04 PM
QWODER's Avatar
What do you mean "to much gas"?Is gas flowing out of the overflow tube or is it bogging down when you give it gas?
Old Sep 16, 2007 | 10:09 PM
mike828's Avatar
I put a spark plug in, it runs good, at high rpms it starts skipping then the plug fouls out and has to be replaced again
Old Sep 16, 2007 | 10:13 PM
QWODER's Avatar
Has anyone changed the main jet in the carb?Has it been running good and just started doing this skipping.Is the air filter clean?
Old Sep 16, 2007 | 10:18 PM
mike828's Avatar
As far as I know, it's factory. I work in the tree removal business and a customer gave it to me several months back. It hadn't been touched in years and I gave it a good maintenance. I don't know what to do about this.
Old Sep 16, 2007 | 10:41 PM
mike828's Avatar
At high rpms the motor is miss firering. I pull the plug and it is **** black.
Old Sep 16, 2007 | 11:12 PM
QWODER's Avatar
Did you clean or change the air filter?
Old Sep 16, 2007 | 11:40 PM
mike828's Avatar
changed it
Old Sep 17, 2007 | 07:07 PM
mike828's Avatar
how do u adjust the carburator so it dont get so much fuel? If u have a diagram that would help.
Old Sep 17, 2007 | 10:58 PM
JRM's Avatar
JRM
float level, todays "oxy" fuel eats the rubber float valve in storeage and this will allow to much fuel to enter. I always run my bikes and quads on premix before storeage as the oil helps protect the rubber carb parts
