I have a dumb question???
Old Nov 19, 2007 | 02:42 PM
LyleStyle's Avatar
Default I have a dumb question???
I'm new to ATV's and I was wondering what the on/off switch is on my gas cap and when do I turn it on and off? Thanks
Old Nov 19, 2007 | 02:53 PM
trx300man's Avatar
It is a vent. If you run it with it turned off the carb can't pull the gas out and it will die. I only turn mine off when I have to load my atv for a haul and have to stand it up on its rear wheels.
Old Nov 19, 2007 | 04:47 PM
megapurt400's Avatar
trx300man cant be more right. When you lift your wheeler up on its grab bar in the rear make sure the "pitcock" is set to off. Also when you transport your wheeler makes sure your "Pitcock" is set to off. The two most important things transporting and wheeler. Never transport it in gear always and I mean always use your Honda givin e-brake, and turn off the fuel. When your tank gets sloshed around it builds up pressure and sends extra fuel up that hose and onto your engine. You will want to start it to get it off the trailer but you will not want it on fire. Make sure you turn it on as soon as you take off the tie down straps as it will run for a few minutes and then die out. Have fun be safe, see you in the mud
JAX HELL HOUNDS
Old Nov 19, 2007 | 06:10 PM
EdKatt's Avatar
My dad's got a 1986 Honda Big Red 3-wheeler and it has that on the gas cap also. I always wondered why it had that!
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
