Honda ATC 125m
Old Jan 24, 2008 | 01:12 AM
jrealmuto's Avatar
Default Honda ATC 125m
if you want to sell it , ill give you $100 and come get it.
Old Jan 24, 2008 | 08:36 PM
joshjines's Avatar
Wher do you even live
Old Jan 24, 2008 | 11:21 PM
jrealmuto's Avatar
mississippi
Old Jan 25, 2008 | 07:48 PM
joshjines's Avatar
thinking about just burning it to the ground all it dose is backfire got the carb clean still back fine used carb cleaner still back fire used starting fluid still back fire spark plug is good spark is good it has white spark im doing every thing but it still wont start i am also using the choke to and i have enen tried it with out the choke <span class="FTHighlightFont">I DONT KNOW WHAT ELSE TO DO!!!!!!!!!!!!!!!!!!!!!!!!!</span ft>
Old Jan 26, 2008 | 12:51 AM
  #15
jrealmuto's Avatar
sell it, if i had it i promise id have it running in 5 minutes
Old Jan 26, 2008 | 03:07 PM
  #16
joshjines's Avatar
then tell me what to do to get it running
Old Jan 26, 2008 | 08:13 PM
  #17
jrealmuto's Avatar
total rebuild on carb, change the oil and filter, brand new plug,battery is one thing that helps alot, if that dont work more likely you have a burnt up piston ect....thats when you rebuild the motor
Old Jan 27, 2008 | 08:20 PM
  #18
joshjines's Avatar
shouldnt it still run with a worn piston qustion what dose oil change have to do with it running. it has good spark carb has a new kit in it i dont know about the plug that is my next option is a new plug. ALSO THE DUDE I GOT IT OFF OF SAID HE WAS RIDING IT ONE DAY AND IT DIED AND HE HASNT MEST WITH IT SENSE. IT BACK FIRES BUT WONT START. also when pull the plug off and it is still connected to the boot and i pull it it ignites the gas could a fould spark plug still do that???????????????????????
THANKS DUDE YOUR ALOT OF HELP
Old Jan 27, 2008 | 08:42 PM
  #19
joshjines's Avatar
sometimes it takes a few pulls to ignite the gas and some times it ignites it right away is that a fouled plug
Old Jan 29, 2008 | 12:37 AM
  #20
jrealmuto's Avatar
dude, i dont know just. all i can say do a total rebuild on things, you cant go wrong with that,just figure it out,you have a long life to live so you got a long time to figure it out,i tried to help.
