Help on a Shifter Issue
Old Feb 23, 2008 | 11:03 PM
demoIL's Avatar
Default Help on a Shifter Issue
I have a 2004 400ex that I just put some Pro Armor Nerf Bars on.. I love the Nerfs but even with the nets loose I seem to have a problem getting my foot under the stock shifter lever.
Is there an aftermarket lever that is maybe an inch or so longer or has anyone else had this problem and found a solution?
Old Feb 24, 2008 | 01:55 PM
demoIL's Avatar
ANYONE???? ANY IDEAS?
<div class="FTQUOTE"><begin quote>Originally posted by: demoIL
Is there an aftermarket lever that is maybe an inch or so longer or has anyone else had this problem and found a solution?</end quote></div>
Old Feb 24, 2008 | 06:34 PM
whaleedited's Avatar
you could cut it and weld a piece in to lengthen it, I did that on my brake lever.
Old Feb 24, 2008 | 07:22 PM
demoIL's Avatar
I just moved the shifter up a tooth and it gave me ok room.. The factory shifter already has a lot of flex to it and I really didn't want to cut it but it's not a bad idea.. I think it would just flex more if I did so it's not quite what I'm looking for..
I think moving it up will serve the purpose fine.. I'll ride it and see..
Thanks
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Schneider
Jul 24, 2015 05:05 PM
Unzzy66
Jul 11, 2015 10:01 PM
