400ex Choke removal
Old Feb 25, 2008 | 11:46 PM
luvmyrottweiler's Avatar
Default 400ex Choke removal
What do i use to plug the hole when i remove the choke?Also what is the best CDI? And what are the advanges of running a 14/40?I love topend but dont want to lose all bottom.
Old Feb 26, 2008 | 07:24 PM
LittleBill's Avatar
why the hell would you remove the choke, those bikes are cold blooded as hell.
Old Feb 26, 2008 | 07:43 PM
Ive been reading that it inproves throttle response.The cold blooded thing is solved by a 42 pilot jet.It will start right up.
Old Feb 26, 2008 | 10:57 PM
go-hard-or-go-home's Avatar
cdi...i like dynatek. they just have so much power!!
and the advantages of a 14/40 are if your rock climbing. man i ran a set of new 14/39 and not a second after i got to third, i took them off. matter of fact if you want em you can have em!(brand new renthal).
y u wanna remove the choke? i mean i read your post,but it s not clickin.
Old Feb 26, 2008 | 11:12 PM
What are you running?Gear wise? I love topend,but im afraid of the 16 tooth.I ride trails and in sand.We drag race alot.
Ok with the choke
http://www.atvriders.com/articles/choke400ex.html
Old Feb 26, 2008 | 11:35 PM
crazy1291's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: luvmyrottweiler
What do i use to plug the hole when i remove the choke?Also what is the best CDI? And what are the advanges of running a 14/40?I love topend but dont want to lose all bottom.</end quote></div>
why are you so worried about losing bottom? when do you actually lug that low in 1st? because that's the only place you will feel a reduction in pulling power- 1st gear @ 3000 ish rpm.
All the other gears will just make you thinkg you are running a gear higher than you really are because you are going faster in the same gear than you normally would.
Gearing taller would probably be better for a rolling start drag since you dont have to deal with that super low rpm 1st gear bog.
And gearing down to launch in 2nd seems to me like just throwing out your 1st gear by making it unusable and throwing out your 5th gear because that now only goes as fast as 4th.
Old Feb 27, 2008 | 01:40 PM
Bounce400ex's Avatar
As far as I've seen this one of the most common mods done to the 400ex. Everyone I know that has one has done this. I would imagine you could just put it back if you don't like it. Here is a pic of one way to do it. A durable material is held in place over the hole with a hose clamp.
Old Feb 27, 2008 | 06:34 PM
crazy1291's Avatar
don't you need to get a 42 pilot when you do this mod?
Old Feb 27, 2008 | 06:35 PM
yup.
Old Feb 27, 2008 | 10:34 PM
What about opening the airbox lid?AND the jetting? I shouldnt have to go up on the main jet right?
