400ex thats gotta be
Old Feb 26, 2008 | 11:02 PM
go-hard-or-go-home's Avatar
Default 400ex thats gotta be
why doesnt my 400ex want to run right unless its all or nothing? it runs like trash if your not yokin, gasin, smackin,goosin,twistin, or breakin the throttle?
anyone know?
Old Feb 26, 2008 | 11:14 PM
southernboyz's Avatar
sounds like your jets are messed up or trash in the carb
Old Feb 27, 2008 | 06:22 PM
factory jet is 148. i put a 416 in it, with a 170. does that seem kinda high? shud i go to a 150?
Old Feb 27, 2008 | 08:26 PM
MisfitRider's Avatar
try going to a 150, and stepping it up from there
Old Feb 27, 2008 | 08:52 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You went to a 416 but did you open up the airbox and install an aftermarket exhaust?
If the airbox isn't opened up (take the lid off) then you jumped up to too big of a main jet.
Old Feb 28, 2008 | 07:40 PM
yeah. got a open air box. and i have a white bros pipe... also runnning 115 octane. nology coil and a dynatek cdi.
it just breaks up 1/4 to 1/2 trottle?????????????????????????
Old Feb 29, 2008 | 11:18 AM
Pirate Biker
Limping Rider!
You went to a 416, what compression did you bump it up to?
If you are running 12:1 or less, 115 octane is not needed and would actually be hindering performance. I would not bump up to race fuel unless you had 13:1 or higher. Then you might want to run 50/50 race gas/pump premium.
Ride it around at 1/2 throttle and then pull the plug and check the color. Tan is the best, black is too rich.
Old Feb 29, 2008 | 09:04 PM
ATV24/7's Avatar
Thats sounds a little high.
Old Mar 2, 2008 | 08:22 PM
fixed it!!!!!!! i just pulled the needle out to the 4th notch and put a 180 main jet.
runs like a top...
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
