trx450r jetting specs
Old Mar 4, 2008 | 05:40 PM
ivotaw12's Avatar
Default trx450r jetting specs
I own a 2005 trx 450r. i have a comlete big gun race series exhaust system, and an open air box with a k&n air filter. what should i do jetting wise, can i just change the main jet...or what?
Old Mar 4, 2008 | 05:52 PM
-Gary-'s Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ivotaw12
I own a 2005 trx 450r. i have a comlete big gun race series exhaust system, and an open air box with a k&n air filter. what should i do jetting wise, can i just change the main jet...or what?</end quote></div>
It depends on your altitude and a few other things. What are you jetted at now?
Old Mar 4, 2008 | 07:20 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You'll need to not only change the main but also the pilot jet and drop the clip on the needle.
Big Gun should have a customer service # that you can call and get a good starting point for your jetting, but a lot will depend on where you ride.
Old Mar 4, 2008 | 08:36 PM
ivotaw12's Avatar
i went online and big gun had specs but none for my quad. i always ride on the dunes at the beach, so i have to be right at sea level
Old Mar 4, 2008 | 08:40 PM
ivotaw12's Avatar
o and my jetting is still stock, i havent ridden it except up and down the street. it back fires all over the place.
Old Mar 5, 2008 | 09:53 AM
Pirate Biker
Limping Rider!
Rejet!!!!!!!!!!!
Do not ride it with the stock jetting with the pipe and airbox mods!!!! You are very lean!!!!!
Start off by adding a 180 main jet, and I think I went to a 42 pilot jet and drop the clip on the needle to the last (bottom) setting.
You may also need to back your air/fuel mixture screw out 1/2 to 1 full turn.
Old Mar 5, 2008 | 11:28 AM
-Gary-'s Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Red400EXRod
Rejet!!!!!!!!!!!
You may also need to back your air/fuel mixture screw out 1/2 to 1 full turn.</end quote></div>
Quted for truth.
If you ride it with stock jetting and aftermarket parts you'll notice it runs worse, MUCH worse.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
01ssls1
Sep 22, 2015 06:50 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
