2007 400ex will not start
Old Mar 16, 2008 | 07:28 PM
Matt1980's Avatar
Default 2007 400ex will not start
We spent all day yesterday trying to start the thing and the most it did was started then it would die but would not stay running. It seems like the choke doesnt do anything but we just serviced it and honda said that it was running fine and there was nothing wrong with the choke or anything and we have had it for six months and always had a heck of a time starting it. if anyone has any helpful ideas please post them. thx
Old Mar 16, 2008 | 07:54 PM
oldturtle's Avatar
This motor likes fresh gas in the float bowl and slightly advanced idle for starting. With my 04 400EX I just open float drain screw on left side of float bowl until I get a steady stream of gas onto the ground. This replaces stale gas in float bowl with better gas from tank. And then if you have good fresh gas in tank it should fire up. For cold starting I give thumb a couple pumps with full choke and it always fires. If it still will not fire then you may have a plugged up pilot/idle jet. The poor gasoline quality in most locations goes bad quickly.
Old Mar 16, 2008 | 08:02 PM
Dans 07400ex's Avatar
i have a 07 400ex too. also hard as hell to start.last time before i parked it i ran carb out of gas it seems to help.gas in your carb bowl might be stail. make sure you have fresh gas in your carb.so drain gas out of carb-take spark plug out and dry cylinder out so its not flooded-pull choke-pump throttle 3-4 times-should start.soon as it starts go to half choke.not good on engine to run on full choke for long.and it could use a 42 pilot jet will help cold starts. kinda easy to flood out dont pump throttle too much!!! let me know what happens
Old Mar 17, 2008 | 03:21 PM
go-hard-or-go-home's Avatar
mine did the same thing...messed with the wires, took the choke off and no probs since!
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
bogie ben
May 30, 2015 04:10 PM
1000gade
May 27, 2015 12:37 PM
