honda 300 run on choke
Old Mar 30, 2008 | 03:45 PM
barrentine's Avatar
Default honda 300 run on choke
I have changed gas rebuilt carb changed spark plug and it will crank and run good at idle on half choke until you throttle up and it bust up.the valve train is a little noisy also. any suggestions.thanks
Old Mar 30, 2008 | 05:29 PM
DWill58's Avatar
It sounds like your valves need to be adjusted, especially if there is a noise problem that you are noticing.
Old Mar 31, 2008 | 10:55 AM
barrentine's Avatar
thanks dwill58,I did adjust valves and it quitend them down but it still will not run off choke.where can i find a carb breakdown.thanks
David
WesTech
11
Aug 11, 2015 07:55 AM
binky79
Jul 30, 2015 06:37 PM
cornermike
Jul 30, 2015 06:37 AM
ghost civic
Jul 27, 2015 03:15 AM
timster911
Jul 13, 2015 01:57 PM
