Honda 94 Fourtrax 200sx
Old Apr 26, 2008 | 08:24 PM
All_stihl's Avatar
Default Honda 94 Fourtrax 200sx
NEED PARTS MANLY SEAT AND RIGHT SIDE ENGINE COVER MAYBE MORE HELLP!!!!!!!
Old Apr 26, 2008 | 09:08 PM
KNOWSALOT's Avatar
The Facility
You can find alot of parts for that quad on ebay routinely. Also check your local salvage yards. But figure out what you have first because there wasn't a 200SX in 1994.
The 1984 TRX 200 was shaft drive, used trailing arm front suspension, and you engaged reverse by pulling on a lever on the left side of the engine.
This model was essentially a 4 wheeled version of the BigRed 200 three wheeler.
The other models below were new chassis designs using an autoclutch version of the 86-87 200X three wheeler engines......
The 1986-1988 TRX 200SX models were chain drive,...had square shaped bodywork and all had 5 speed transmissions.
The 1990-1991 TRX 200 was chain drive,....had rounded bodywork with a "turtle shell" trunk feature and had 4 speed transmissions.
The 1991-1997 TRX 200D TypeII was the same as the last mentioned only it had racks instead of the trunk. 91 models were 4 speeds. 92-97 models were 5 speeds.
If you still aren't sure which model you have, post the frame and/or engine serial numbers on here.
Old Apr 26, 2008 | 10:05 PM
All_stihl's Avatar
I have the type 2 5 speed I'm a big seller on ebay and check all the time but no luck yet. Thanks for all the great info that will help out a lot the honda dealer here didn't tell me it wasn't a 200 sx when I told them I had a type 2 200 5 speed they agreed with me when I asked if it was a sx. but anyway this will help check me out on ebay if you get a chance chrissford is my user name. Thanks again
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
