450r rocker wore out!
Old May 4, 2008 | 11:12 PM
zooooom's Avatar
Default 450r rocker wore out!
My '05 450r spit out the needles from the roller rocker. Has anybody seen this before?
Old May 5, 2008 | 01:01 AM
DWill58's Avatar
nope, but if you are replacing it, get the lightweight aftermarket one to replace it. I think Sparks sells one, not sure if anyone else does.
Old May 5, 2008 | 01:52 AM
contentsunderpressur's Avatar
You need to check to make sure your getting the proper amount of oil up there.
Old May 5, 2008 | 03:49 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Got to ask what oil you use? What are the usual ambinent temperatures where you ride, and what weight of oil do you run???
Old May 5, 2008 | 12:41 PM
I'm not sure what brand or weight you should use. I've never had a sport quad before. I don't think it would be the brand or weight though, sounds more like starvation to me to the top end.
Old May 5, 2008 | 01:36 PM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: contentsunderpressur
I'm not sure what brand or weight you should use. I've never had a sport quad before. I don't think it would be the brand or weight though, sounds more like starvation to me to the top end.</end quote></div>
Just exploring all the possibilities!
Old May 5, 2008 | 02:26 PM
Could have also been a faulty bearing.
Old May 5, 2008 | 03:37 PM
Red Rider
I have not heard of this before, so it is most likely a fluke part that failed.
Old May 5, 2008 | 03:45 PM
I've never heard of it either. I didn't see that it's an 05 model so that's probably all it is. If it happened again I'd look into more then. Good luck.
Old May 6, 2008 | 08:46 PM
zooooom's Avatar
I rode it 4 hours. It started ticking like the valves were loose. I knew it had shims so I took it to somebody that had the shims and when he pulled the valve cover he saw the needles hanging out of the roller. Tore it down and the piston top looks pretty clean for an '05. I hope it WAS a fluke. It really makes me sick to tell you the truth!
