honda recon help
Old May 17, 2008 | 10:45 PM
mudb0ggers's Avatar
Default honda recon help
well when i give it little to any gas it bogs down
it will move maybe 4 inches then it shuts off
i have cleaned the air filter and a filter under that?
this has happend many times...
it gets very annoying!!!
it seems to do this after i go over a jump
Old May 17, 2008 | 10:55 PM
mudb0ggers's Avatar
also this HAS HAPPEND before i got hte mudlites
Old May 19, 2008 | 11:24 AM
wlvrn's Avatar
it sounds like your having the same problem im having. but you didnt say if you had a snorkel on yours like mine. i am going to take the carb out and clean it good and check the jetting again since i just rejetted it last week for the snorkel. maybe you should take the carb off and give it a good cleaning. have you had it in any water lately? could there be any water in the air box or carb? how clean is your sparkplug? those are just a few things to check.
Old May 19, 2008 | 02:48 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Before I took the carb off for cleaning I'd loosen the Drain bolt on the bottom of the carb and drain out the gas and water in the bowl. A lot of times it's all it will need. Water can collect in the bowl. There is a black drain tube coming off the bowl put that in a can to catch the gas. Be sure and turn off the gas at the tank so you dont drain it to. How about your air filter? Have you clean it and put too much oil on her?
Old May 19, 2008 | 04:19 PM
mudb0ggers's Avatar
well my neigbor came over (big fourwheeling guy) and he said it wasnt getting enough gas?
we took the carb apart drained the bowl and cleaned it out? it runs the same with the filter off
so now i got to go spend more flipping money of the piece o junk
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
