Which Pipes & Such for 400EX??????????
Old Jan 24, 2001 | 06:58 PM
wheeliedude's Avatar
I'll be getting that issue soon, but just 2 more questions.What was the average peak hp with the K&N filter and 155mj, and an average pipe on it? What was the stock hp? Thanks
Old Jan 24, 2001 | 07:38 PM
coryatver's Avatar
LRD was not in the shootout. The White bros and ct were the best and only gained 1 hp at peak. The stock had 26.9 peak hp. The white bros and ct pipes with a k&n filter and 155 mj it was 27.9.
HP at 4000rpm was 13 stock and the top 2 pipes for that were the ct with 16.3 and the pro circut with 15.9
Go buy the magazine its a good issue. Quadfather got a letter printed in it!
Old Jan 24, 2001 | 10:44 PM
bung's Avatar
I bought the DG Alloy HP2 exhaust and it Sounds great and It's only $250.00. Seriously, DG is the way to go. I've got low end power and it added 7 or 8 Horsepower
Old Jan 27, 2001 | 10:21 PM
ripinBanshee's Avatar
if u want a slip on the Big gun is the best for u if you have your valve adj and throttle tuned the big gun is the best my friend has one and it is great has lots of low end as well as top Wb is not a bad pipe i would not suggest it
Old Jan 28, 2001 | 12:00 PM
  #15
00HondaEX's Avatar
The CT was also the loudest at 102db. While the White Brothers made the same HP but only a 95db level.
Old Jan 28, 2001 | 02:47 PM
  #16
LDJ's Avatar
LDJ
I called LRD and asked them about their pipe. He said that the next issue of ATV Sport there is a major full exhaust shootout, and the LRD ranks #2.
The best pipe is the white bros pro meg complete, but he couldn't remember the rest of them. He said that he thinks white bros did a big pay off on ATV Sport to get the #1 award.
For the guy who wants to get rid of his LRD system for a CT, there is know way a slip on could compare to a complete system,the LRD pipe is probably in the top 3 of all 400EX pipes.
If you are looking into pipes, you have to look in the long run, if you are planning to build your engine at all, most of the brands out there will restrict flow. I personally think these are the best pipes for the 400EX: LRD,Curtis Sparks X-6,DMC,GT Thunder,and the white bros. These are all complete systems.
Old Jan 28, 2001 | 10:11 PM
  #17
jcv400ex's Avatar
I like my WB E series. I had the PowerCore IV and I sold it after 2 weeks. WAY TOO LOUD! The WB adds low to mid-range power without losing any top end. And you can tune it to go either way. I'm going to add 6 more disks this spring. Right now I've got the standard 12 in and I'm running a 160 main. I've got a 3" dia hole in the air box. It runs great. And the sound is just right. For 240 bucks, I don't think you can go wrong with it.
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
