Can a CDI unit cause a weak spark?
1986 Honda TRX250R Fourtrax.
Was running poorly above ½ throttle. Cutting out. Runs okay at 1/8 to ½ throttle.
The bike is hard too start. I thought the problem was in the carburetor, but after going through the carb I checked the bike for spark. The spark was weak (small and yellow). [I checked for spark in a dark shop, so not to have the lighting drown out the spark]. I could get the bike to backfire, but that was all. Here are the parts that I checked:
1. Pick up coil - in spec at 118 Ohms
2. Primary winding of coil - 0.4 Ohms (do not know spec)
3. Secondary winding of coil - 1.4 Ohms (do not know spec)
4. Stator - visually looked okay
5. Flywheel - visually looked okay (none of the magnets went bad).
I also replaced the following:
1. Stator
2. Flywheel
The only part that I do not have to replace the CDI unit/(black box).
Has anyone else had a experienced this?
Meantime I am trying to find a (known good) CDI to borrow.
Any help is greatly appreciated,
Thanks,
John
P.S. How do you check the output of the stator. Is it suppose to be 12VDC?
1. Stator
2. Flywheel
Thanks,
John
Sorry I took so long in posting my findings.
The problem was a weak/interminent grounding of the aftermarket kill switch.
Disconnected the kill switch and the bike runs great.
Thanks,
John
Thanks,
John
