1987trx 250 four trax
Old Jul 17, 2008 | 08:49 PM
hndgnr's Avatar
Default 1987trx 250 four trax
my 250 just quit runnung one day. i have it all apart can see all the wires have a new cdi ,have three different regulaters they all test the same but not exactly as the clymer manual says? the stator assembly test correct the coil test correct the fuses are good the lights work the motor cranks. one thing i don't get is the neutral light stays on and it will crank in any gear,also the oil temp guage doesn't come on when you turn the key on I don't if this is anything. pleaseI need help
I need suggestions Iam lost here. thanks ahead of time Jerry
Old Jul 17, 2008 | 09:06 PM
tigercubii's Avatar
you need 3 things.... spark, compression and fuel.
what do you have???
Old Jul 18, 2008 | 07:37 AM
HondaMechanic's Avatar
Here are the Honda ignition tests .. Don't do the CDI test it isn't a reliable test unless you have a Sanwa sp10d or sp15d tester .. Sounds like someone wired the neutral to ground Here is the neutral test ..
Old Jul 18, 2008 | 05:34 PM
hndgnr's Avatar
thanks for all the info once again ididn't even know such a tester exsited until now. I've tested everything with a multi tester. but why does the neutral light stay on even if I unhook the neutral switch? again thanks alot for the help. Jerry
Old Jul 18, 2008 | 05:42 PM
The neutral works by ground , sounds like someone grounded the wire somewhere and you'll have to trace the wires to find where..
Old Jul 20, 2008 | 09:15 PM
hndgnr's Avatar
It"s alive, finally after for ever the trx is fixed .I found a bad connector on the stator to reg. wires I think there was more than one problem along and along bettween the choke spark plug and a wire. somehow I got it started, running crappy tho, I had rebuilt the carb before the bike completly stopped running , I took it off the choke was stuck open closed it put the carb back in started and ran great I was beside myself.S tarted to put everything back together got a good way along tryed to start it again ,no go ,i say what the f is going on ,no spark again, so I finally went out and bought a spark tester instead of trying to hold the plug against the head took the air box and stuff back off started wiggelingwires and connectors that I might have moved putting it back together while trying to start it and that is how I found the baaaaaaddd wire .thanks for everyones input Man I've learned alot from this adventure. I could go on but Iguess I won't [img]i/expressions/face-icon-small-happy.gif[/img]
4trax67
ATC 3-Wheelers
Sep 1, 2001 09:21 AM
4trax67
Aug 30, 2001 05:51 PM
hondatrx300
Aug 22, 2001 05:04 PM
Kodiak01
Jun 26, 2001 06:58 PM
tbass2
Dec 6, 2000 03:30 PM
