need help for honda fourtrax 300
Old Aug 17, 2008 | 10:16 PM
jackie63's Avatar
Default need help for honda fourtrax 300
I have a honda fourtrax 300 . It will not start. When I push the starter button, I can hear the starter relay clicking. The battery is fully charged. On occasion, it will start right up. Could this be a loose wire or does the starter act this way. I'm not mechanically inclined.
Old Aug 18, 2008 | 06:53 AM
HondaMechanic's Avatar
The starter will probably need to be re-built or replaced .. You have to test it with a volt meter ... Put the negative (black) lead of the volt meter to a good ground , put the positive (red) lead of the volt meter to the starter positive post (it should be under the rubber boot) now turn on the key and push the starter button ... If you hear the soliniod click and battery voltage registers on the volt meter then the problem is the starter ..
Old Aug 18, 2008 | 07:52 PM
jackie63's Avatar
Ok , thanks alot. I'll try that.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
