HRC 07 450TRX Pinging?
Old Sep 2, 2008 | 03:40 PM
lefty1's Avatar
Default HRC 07 450TRX Pinging?
Just wondering if anybody is running 110 race fuel on an HRC 450. This last weekend it was "pinging" when i was in 3rd with it buried on the throttle, drop to 2nd and it would stop. I know the are rev monsters, but it was pulling hard still, just a few pings here and there. I have always run super in it, but may try a 50/50 mix. I just adjusted the valves abuot 20 hours ago, so I know they are do, just wondering if I need to do more valve inspects or jump the octane up???
Old Sep 2, 2008 | 06:12 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I run a little Klotz Octane Booster in 93 octane pump gas, just to be sure I never detonate.
Are you just running hot, because of the hot weather?
Old Sep 2, 2008 | 06:33 PM
lefty1's Avatar
I doubt it is running hot...65 and breezy on the Oregon coast [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 2, 2008 | 08:39 PM
Red Rider
.....ah, we stayed home from Oregon Dunes this year because of fuel costs!
Old Sep 3, 2008 | 04:55 PM
lefty1's Avatar
It was a great ride. Cool weather and great sand conditions.
Old Sep 3, 2008 | 05:39 PM
kukerdan's Avatar
recon why dont you just buy 93 or 94 octane?
Old Sep 3, 2008 | 06:04 PM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: kukerdan
recon why dont you just buy 93 or 94 octane?</end quote></div>
I actually meant 93. The recommended amout of booster raises it 2.5, so I end up with 95.5. Better yet, the booster also contains a fuel preservative (good for 1 year), it absorbs moisture, and contains an ester synthetic lube for the upper cylinder!
Old Sep 3, 2008 | 09:08 PM
Doctorturbo's Avatar
GOT BOOST!
Valve adjustment and pinging have nothing to do with each other.
If this is the first time this happened, I would suspect that you got ahold of some flat gas. I would just try some new premium gas and see what that does.
Another trick I have done is dump two ounces of toluene in / gallon of gas. You can get it by the gallon or fiver at any paint store.
Old Sep 3, 2008 | 10:41 PM
Red Rider
The 06 and later engines have a kind of chatter that they do if they are not ridden reved out. These engines don't lug! Are you perhaps lugging it and mistaking that sound for a ping?
Old Sep 4, 2008 | 03:43 PM
lefty1's Avatar
I don't think so, but I could be wrong. I am in no way a stellar mechanic, but the more I read the more it sounds like detonation. Can someone dummy down this term for me? Exactly what it is and what causes it? If I am correct it is a simple octane issue, as suggested, I could have gotten some flat gas, but I think for future rides I will run a mix (gallon of 110 and 4 93 pump) and see what happens. Can't hurt anything.
