new 05 recon
Old Oct 8, 2008 | 10:43 PM
700 sportsman's Avatar
Default new 05 recon
top speed is around 50-55 mph
I don't think you should need a service manual for the routine maitnance
Old Oct 8, 2008 | 10:52 PM
Hawkman300's Avatar
k, well ill get to workin on it tomorrow afternoon and see how it goes... thanks for the help guys!
Old Oct 8, 2008 | 11:09 PM
Hawkman300's Avatar
what type of oil would i need if i just went to an autoparts store? because thats what i will probably have to do.
Old Oct 9, 2008 | 01:43 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
<div class="FTQUOTE"><begin quote>Originally posted by: Hawkman300
what type of oil would i need if i just went to an autoparts store? because thats what i will probably have to do.</end quote></div>
It is possible that an auto parts store will have the right oil, but certainly not a given. Three things to look for: The oil should be motorcycle specific and be rated API SG/JASO MA. The SG insures that it has at least a descent additive package, and the MA insures that it does not contain friction modifiers that will make your clutch slip.
It is just best to stay away from all the "car" oils! They contain friciton modifiers that are not good for your clutch, and they have downgrade additive packages, becasue of catalytic converters. I won't even run that crap in my car!!!
Old Oct 9, 2008 | 08:43 AM
  #15
Hawkman300's Avatar
k, thanks for the help. ill go by autozone after school and see what i can find and get to work on it this afternooon.
Old Oct 9, 2008 | 09:30 AM
  #16
Red Rider
k, thanks for the help. ill go by autozone after school and see what i can find and get to work on it this afternooon.</end quote></div>
Don't let them stick you with the wrong oil! It can do more harm than good....
Old Oct 9, 2008 | 10:17 AM
  #17
Hawkman300's Avatar
k, well ill go by an auto parts store this afternoon and see what i can find and get to work tonight.
Old Oct 9, 2008 | 07:46 PM
  #18
Hawkman300's Avatar
k, went by the autozone today and got valvoline motorcycle 4 stroke oil. just removed and emptied the full gas tank and now the oil is draining out of the engine. for filling the engine back up with oil, do i just put it in the oil check hole on the top of the crankcase like an atv that just uses normal car motor oil? or do i have to put it in 2 locations, like in the transmission or something?
Old Oct 9, 2008 | 08:35 PM
  #19
Red Rider
Engine and trans share the same oil, so there is only one fill/dipstick hole. Takes a little less than 2 quarts, as I recall.
Old Oct 9, 2008 | 08:39 PM
  #20
Hawkman300's Avatar
ya, i found that out... just bought one quart when i went there, got home, looked in manual and it takes 1.6 quarts, so ill have to either get another quart tonight or tomorrow.
