450R pros and cons
Old Nov 9, 2008 | 10:08 PM
balanis03's Avatar
Default 450R pros and cons
Could some one tell me the pros and cons of a 450R im looking to buy a used one and how much should i expect to pay for a good condition used 450. Thanks
Old Nov 10, 2008 | 02:11 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
These engines are all rev. They are great for going fast in more open country, but they aren't the hot setup for tight trails (lots of clutch slipping required).
Great handling and the stock shocks are good (if you take the time to set them up correctly). I have mine widened +3 by simply using wider tires and rims with a greater offset (ITP XC's on ITP Baja rims)...it corners like it is on rails! I can bash through big desert whoops at full throtle.
All the 450's (not just the Honda), require frequent oil changes! Here is why:
http://www.belray.com/scripts/...41d7-b921-64a4cf6d0144
Nice thing....the Honda seperates the engine and trans oils, so you can run a slick friction modified oil in the engine side, for some extra horsepower! I run Redline MC oil in the engine side, and their 80W Gear Oil with ShockProof in the trans.
http://www.redlineoil.com/prod...oil.asp?categoryID=11
http://www.redlineoil.com/prod...oryID=16&categoryID=6
Some good oil reads:
http://www.thumperfaq.com/oil.htm
http://www.sportrider.com/tech/146_0308_oil/index.html
Old Nov 10, 2008 | 02:16 AM
Red Rider
Also, the 04/05 has a different engine than the 06 and later. The 04/05 is overbuilt and has an oil cooler. Once the CRF450X came out, Honda went with a similar engine for the 06 and later models. Also, a few chassis changes (longer swingarm and a little wider front end) on the 06 and later models.
Some deset race teams will only run the 04/05, if that tells you anything....
HRC kit is the best modification bang or your buck, and will make it scream on the mid to top end.
bmxatv10
Oct 14, 2022 06:23 PM
Customer Service #1
May 15, 2020 08:46 AM
Sep 15, 2015 02:42 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
