2004 Rubicon 4x4
Old Dec 6, 2008 | 03:47 PM
tlanham's Avatar
Default 2004 Rubicon 4x4
When I place in reverse, the engine begins to skip, almost like the cold weather choke is on. Any ideas?? Also, what battery is best?
Thanks
Old Dec 6, 2008 | 04:41 PM
HondaMechanic's Avatar
Is the gear position indicator not flashing a code..?..
Old Dec 6, 2008 | 04:54 PM
tlanham's Avatar
No sir, no codes. It's weird, machine runs great but when you put it in reverse it seems like it's skipping and bucking. This is a 2004 but it only has about 30 hrs on it. It's garaged and practically new. Thanks for any help.Oh, btw, can you check for codes that will tell you the problem?
Thank you
Old Dec 6, 2008 | 05:04 PM
Have you checked the switches on the brake handle .. Make sure the left handle brake lever is turning off the "start in gear" switch ..
Old Dec 6, 2008 | 05:16 PM
tlanham's Avatar
OK, I'll try that and let you know.
Thanks for the time!
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 15, 2015 02:45 PM
