honda 300ex part 2
Old Dec 22, 2008 | 11:19 PM
lilc9928's Avatar
Default honda 300ex part 2
well i got my solenoid, starter cable, and the positive and negative cables.
Going outside to put it on right now.
I'll update you guys if it starts. I'll take a video too.
Be Back Later...
Old Dec 23, 2008 | 01:24 AM
lilc9928's Avatar
ok i hooked everything up....NOTHING!!!
I tried to start it by pushing the electric start button, that didnt work so i tried to start it by using a screwdriver by touching the solenoid, nothing.
Im pretty much clueless AGAIN!!!
The batteries good, I know that for sure.
I hoping the solenoid that came in today is good from what the guy said. But you never know. I figured out that i could get one cheap in town so maybe i'll buy one and if that dont work take it back for a refund i guess.
I got all different wiring. So what do you guys think whats wrong with it???
I just really want to get this thing running!!!
Im just getting tired of working on it. Its been very cold for the last few days (yesterday was -2 to -3 degrees all day, today was from -2 to 3 degrees).
But please reply back thinking of what you thinks whats wrong with it!!!
Thanks,
Old Dec 23, 2008 | 02:08 AM
lilc9928's Avatar
Found the problem!!! [img]i/expressions/face-icon-small-smile.gif[/img]
I started reading online and i seen that somebody said that they tapped on there starter while trying to turn it over and it worked.
So i tried to turn it over and i tapped on the starter, Walla, it turned over.
It wasnt very strong though. it turned over for maybe a couple seconds then stopped so i tapped on it again and it started to turn over then stopped.
Do i need a new starter???
Old Dec 26, 2008 | 11:18 AM
eprovenzano's Avatar
Are you sure the battery has a full charge?
Old Dec 26, 2008 | 10:48 PM
  #15
lilc9928's Avatar
I bought a starter and it now turns over.
But thanks for the reply eprovenzano
Thanks everybody for your help.
Old Dec 31, 2008 | 06:56 AM
  #16
Y2daT's Avatar
let us know if u get her running..ive been away for a while but im back now.....
Old Dec 31, 2008 | 03:03 PM
  #17
lilc9928's Avatar
i need the banjo bolt for the oil line then im completely done with it. im not able to get the part until the 2nd. i might have to order it then it'll be another week from the 2nd. but i will let you guys know when i get it running and i'll tape it.
thanks for your guy's help.
Old Jan 8, 2009 | 10:55 PM
  #18
lilc9928's Avatar
got the part today. put it on and tried to start it. i tried for maybe 2 minutes tops then the battery wouldnt turn it over anymore, its dead. charging the battery tonight. any ideas how to get it started?
Old Jan 12, 2009 | 06:33 PM
  #19
brungardt's Avatar
is it for sure getting spark? and also..(if it is) spray some carb cleaner down the air box hole into the carb and crank it....thats what i had to do everytime with my old SKUD 4 wheeler//
Old Jan 12, 2009 | 09:28 PM
  #20
lilc9928's Avatar
well it fires up for like a second when i try to start it but then it'll just die. i keep doing it and it keeps doing the same thing. U think i should clean the carb? i already put a new plug and new gas.
