oil in air box??? why
Old Dec 27, 2008 | 11:34 AM
NoJoKe23232323's Avatar
Default oil in air box??? why
can someone tell me why my 400ex gets oil in the air box. i mean i filled up my oil tank. then i checked my oill it was empty. somehow it got into the airbox please someone help
Old Dec 27, 2008 | 11:54 AM
TLC's Avatar
TLC
Roll overs,tip overs and steep hill climbing and descending will cause oil to get into the air box from the crank vent hose. Also if you over fill the oil level the excess oil will blow into the air box as well.
Old Dec 27, 2008 | 12:01 PM
thanks man i really apriciate it what do i do just clean everything out right?
Old Dec 27, 2008 | 12:09 PM
TLC's Avatar
TLC
Just clean it out,and make sure you oil level in correct. Happen to me and others I ride with a few times,does not seem to hurt anything but can't be good for the ATV's breathing if the air filter gets oil on it.
Old Dec 27, 2008 | 12:35 PM
zitaron's Avatar
also check that there is nio gas mixed in with that oil - 'cos thats another story - - always check the dipstick, simple but I've rebuilt 4 engines this year cos guys didn't check oil level
Old Dec 27, 2008 | 01:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Perhaps your rings are bad? That allows compression to get past the piston and into the crankcase. From there, the only place it has to go is out the breather hose. In the process, it takes some crankcase oil with it....
It is puzzling however, because the crankcase breather on the 400EX is after the airbox. The only place for oil to come from is from the breather, and it should get sucked up into the carb and not back into the airbox.
Check your breather. It has a white plastic reservoir on the end. Is it loaded with oil????
Old Dec 27, 2008 | 04:50 PM
billybob101's Avatar
i have a 2003 honda rancher mine is also filling the breather box with oil and now has sstarted to pour through the exhaust is it just rings that cause this
Old Dec 27, 2008 | 08:53 PM
Red Rider
On the Rancher, the breather is in the airbox. It is that slot under the air filter, that should have a piece of foam in it. If you haven't overfilled the crankcase, most likely you are passing compression.
Old Dec 27, 2008 | 08:55 PM
Red Rider
Maybe just drain down off your oil filter?????
http://forums.atvconnection.co...tid/21/threadid/556480
Old Dec 27, 2008 | 11:05 PM
Stoopidbot's Avatar
Recon, we may have our differences but I agree with you 100% here!!!
