87 250X
Old Jan 15, 2009 | 06:17 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 87 250X
The snorkle and confines of the airbox, are more restricted than the maximum amount of air that the carb can handle. Some things you just have to take on faith. Millions of people (including myself) have had the exact same experience!
Old Jan 15, 2009 | 08:27 PM
sprayedgt's Avatar
Default 87 250X
Its all about velocity and being lean. The less restricted opening is not allowing the air to enter with enough speed. Volume is nothing without velocity. It seen it personally while experimenting on the chassis dyno.
Old Jan 15, 2009 | 08:59 PM
budedm's Avatar
Default 87 250X
So that's why it runs better with the lid on? Because the air coming through the openings that lead from outside air to the box is flowing fast and when I open the lid, even though there's more air, it's moving slower so I lose power?
Old Jan 15, 2009 | 09:02 PM
sprayedgt's Avatar
Default 87 250X
Yes exactly.
Old Jan 15, 2009 | 09:47 PM
  #15
budedm's Avatar
Default 87 250X
Ok, I get it now. What if I make the hole in the carb a little smaller? Will it flow faster and have more power? Or is it a thing where smaller is better because the velocity is faster but too small and you cross the line where you start to lose volume? So it's a trade off between volume & velocity?
Old Jan 15, 2009 | 09:53 PM
  #16
sprayedgt's Avatar
Default 87 250X
Big is good only if you need it. You can make the carb opening as big a a coffee can and add the appropriate fuel, but make no power. You need to find the spot where volume and velocity intersect to determine the perfect size for your combo.
Old Jan 15, 2009 | 09:57 PM
  #17
budedm's Avatar
Default 87 250X
OK. Now I'm educated. Thanks sprayedgt.
Old Jan 15, 2009 | 10:09 PM
  #18
sprayedgt's Avatar
Default 87 250X
No problem man.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
