need help on my honda
Old Feb 7, 2009 | 05:06 PM
250Xftw's Avatar
Default need help on my honda
I need help finding a cheap 250x bottom end with the gears in it, cause my 3rd gear seems to be about shot. anyone help me out?
Old Feb 7, 2009 | 11:01 PM
johnboy27's Avatar
ebay has like 2-3 full good gear sets right now.
Old Feb 8, 2009 | 06:29 PM
Y2daT's Avatar
how much is cheap?and are you near N.C.?
Old Feb 8, 2009 | 06:50 PM
250Xftw's Avatar
I know nothing about spliting the cases other than it's a pita. How much would someone charge to replace the gears if you had them? Yes I am in Winston-Salem, North Carolina.
Old Feb 8, 2009 | 06:52 PM
250Xftw's Avatar
cheap, ummm around 80 bucks is what i got right now lol. less than 200 i guess but i don't have it right now.
Old Feb 8, 2009 | 07:02 PM
Y2daT's Avatar
i have a 250x motor that locked up last may..but ive been hoping to rebuild it.
all the gears including reverse worked ,and the clutch was easy to pull but dintend slip
i accidently ran it out of oil before it locked up and it started making bad noises ..my freind was following me and stalled out when he got hung on a vine and it hasnt turned over since ..so I dont think its busted but I havent taken it apart to find out....
im guessing the top end seized (broke ring?) but the noises it was making means it may need crank shaft and or connecting rod berrings...it would be a gamble on weather or not the cases have to be split..but i feel that all the gears are good
Old Feb 8, 2009 | 07:11 PM
Y2daT's Avatar
it also needs a left side cover ,from where the chain rubbed a hole in it ...I guess i could pull the top end and check to see whats wrong and go from there ....I need to buy a piston kit and get a head fixed to get my other 300ex motor fixed..i could let the bottom end go for 150.00 i guess .(minus the topend and stator)..but id like to see what needs fixed first so you dont get a bad deal ..
Old Feb 8, 2009 | 07:38 PM
250Xftw's Avatar
where abouts in nc are you at?
Old Feb 8, 2009 | 08:36 PM
Y2daT's Avatar
Jacksonville
Old Feb 8, 2009 | 08:44 PM
250Xftw's Avatar
ok well keep me updated on it
