250x not running rite
Old Mar 6, 2009 | 09:30 AM
redneckrider9's Avatar
Default 250x not running rite
was riding the bike the other day it died sounded like it ran out of gas towed it back it had gas,pulled the plug it was fould,put new one in it starts but spits and sputers any one got any ideas,id appreciate it
Old Mar 6, 2009 | 11:48 AM
dave 570's Avatar
probably not your problem, but i have bought bad spark plugs before. just a thought.
Old Mar 6, 2009 | 02:23 PM
trailbuzzer's Avatar
Might be your choke ckt. Perhaps the cable/pin into the carb isnt moving when adjusted, and its always choked. Or perhaps your float in your carb is stuck open. Are you noticing any gas running down from the bowl when your atv is shut off?
Old Mar 6, 2009 | 03:41 PM
its not leaking gas,its allmost like its starving for gas,all take it apart and check theks choke than
Old Mar 7, 2009 | 02:39 PM
quadketh's Avatar
well could be cdi box maybe
quadketh's Avatar
does it only do it after warming up?
Old Mar 8, 2009 | 01:26 PM
it does it as soon as you start it,it will fire rite up.just will not run
Old Mar 8, 2009 | 02:54 PM
quadketh's Avatar
its probably got trash in it so try cleaning out the carburator b/c like trail buzzer said your float could be stuck it will flood it and make it seem like its out of gas but it should smoke when it splutters.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Mphillips
Jul 29, 2015 08:53 PM
big_g_squared
Jun 28, 2015 04:17 PM
