1986 TRX200sx squealing noise
Old Mar 10, 2009 | 04:21 PM
xbassman's Avatar
Default 1986 TRX200sx squealing noise
Sometimes, not all, my TRX200sx makes a squealing noise, like metal to metal and I believe it is coming from the rear. Seems only to squeal when I turn left. Took off right rear and cleaned shoes (new) and greased everything I could think of. Might be the left rear bearing? Anyone had this problem? It is a pulsing squeal.....like squeal, not, then again, then not, then squeal????
Old Mar 10, 2009 | 08:32 PM
gambler_m_99's Avatar
Sounds like the rear bearing to me. If you have alreaady checked one I would for sure look at the other one.
Old Sep 30, 2010 | 03:20 PM
Rpm90001's Avatar
Same problem here? Did you change the bearing? Fix the problem?
Old Oct 3, 2010 | 01:23 AM
JRM's Avatar
JRM
common issue on this quad, and dont over tighten the axle bolts
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
