help!!!!!!!!!!!!!!!!!!!!!!!!!
my 2003 honda rancher ES 350 5 speed, wont shift, i cant even shift it manually, i was riding it, and i down shifted and it is now stuck in 1st gear, it wont start because its now in neutral, it has a electronic clutch, i can move the foot peg about 80 degrees then it will stop, need a way to get it back into neutral please help
Same thing happened to me. I had to replace the shift plate in the very front of the motor. The earlier 2000 thru 2004 were notorious about doing this. Honda had an update a few years back but it has expierd. It is an easy fix if you do the work yourself and the part cost is about 45.00. When you remove the old shift plate look VERY close and you will see they have spread or broke.
To get it to start now find the set of wires that come out of the bottom rear of the motor by the pull rope. Most loop up over the engine right in front of the top of the pull rope. Bare the rubber coating and find the green wire strip a little and wrap a piece of wire around it and ground it. Your neutral light should now be on and the four-wheeler will start even though it's in first gear. When you get it fixed properly just tape the stripped are of the wire and the rubber coating. I had to do this to my Recon as being that when they rebuilt the bottom end they put the sensor in the wrong spot making the four-wheeler think neutral was between 3rd and 4th gear. I did what I told you to do and it will start no matter what gear it is in.
yeah.. thats why i dont really care to much for the rancherES i would rather have the ol foot shifter.. but i rode with this guy that had the same problem and we would just let it sit and rock it back and forth and eventually it poped in neatural but it kept gettin stuck over and over
also does anyone know how much and ECM cost i cant find out anywhere
