just adjusted the valves, now no spark
Old Apr 3, 2009 | 07:48 PM
angler's Avatar
Default just adjusted the valves, now no spark
I have a 2005 Rubicon. I just got done adjusting the valves and before I put everything back together, I hooked the fuel tank up and tried to start it to see how it ran. It would turn over but would not start. I took the spark plug out and there was no spark. I found out the tip came off the spark plug and is inside the spark plug boot. Even though the tip came off, shouldn't it still get spark? Has anybody else had this happen?
Old Apr 3, 2009 | 11:28 PM
johnboy27's Avatar
is the plug broken or did the terminal top just screw off?
Old Apr 4, 2009 | 01:55 AM
JeffinTD's Avatar
If the tip actually broke, it may have a crack inside that isn't conducting very well.
I'd try sticking another plug in it before I'd dig in any further.
Old Apr 4, 2009 | 04:24 AM
HondaMechanic's Avatar
The "IJR7A9" spark plug for the Rubicon doesn't have the thread on tip installed ..
Old Apr 4, 2009 | 07:05 AM
angler's Avatar
I did not realize that. So could the piece that is inside the boot be bad? If there is a problem with the boot, can that be replaced?
Old Apr 4, 2009 | 07:34 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Don't know Honda, but doesn't the cap pull off?
Old Apr 5, 2009 | 09:54 AM
angler's Avatar
Now I am getting spark and will start. But now I got another problem. It will not run good at all. It will not idle. If I give it gas, it will stay running but as soon as I let off the gas it will die.
The first time I started it after I got done adjusting the valves, it started right up and would idle but it almost sounded like the choke was pulled out. But after a few seconds, it would not idle anymore.
I am also still getting the rattling noise. So it must be something else besides the valves.
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Unzzy66
Jul 11, 2015 10:01 PM
MNatv89
Jul 7, 2015 11:36 AM
