99trx400 forman dies above high idle.
Old Apr 4, 2009 | 06:25 PM
pinetime's Avatar
Default 99trx400 forman dies above high idle.
problem started with the engine cutting out at higher rpms under load. it got worse to the point where now the only way i can even get it started is to rapidly hit the starter button repeatedly or hit it as pulling the cord. if i hold the starter button down it has no spark. when it dies after reaching just above high idle it is as though a certain rpm triggers the ing. to shut down. same rpm every time. idles fine but as soon as i hit the trottle dead at the same rpm.. i'm frustrated and would appreciate some advice and or info to help w/prob.. thanks in advance-- AV
slowgsxr97
Mar 18, 2022 03:40 AM
dwhipper61
Aug 27, 2015 11:01 AM
Knackknack
Aug 19, 2015 07:45 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
