98 Honda forman backfire problem
Old Apr 6, 2009 | 12:00 PM
evvlb2's Avatar
Default 98 Honda forman backfire problem
Ok so here is the problem I have a 98 Forman S just did a top end job on it, new piston, rings, valves, valve seats and had to boar it over .025. I also put a new muffler on it that I bought from huperparts.com that is supposed to be just like stock.
But know it back fires when you engine brake. I don’t know If the carb need to be jetted or if the new muffler that doesn’t have enough back pressure. I know the valves are adjust right and everything that got put back together right and in the right order.
Any information would be greatly appreciated
Old Apr 6, 2009 | 02:19 PM
tallman01's Avatar
maybe running to lean, need to adjust carb and richen the mixture
Old Apr 6, 2009 | 09:01 PM
monkeywrench321's Avatar
also check that the air filter is connected correctly and the boot from the carb to the cylinder is not damaged or if its on snug.
Old Apr 7, 2009 | 08:25 AM
evvlb2's Avatar
tallman01 was right i adjusted the pilot screw on the carb cleared it right up thanks for you input
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
ranvette
Jul 4, 2015 06:13 PM
