Steering help
Old Apr 19, 2009 | 05:46 PM
rancher5's Avatar
Question Steering help
hi, i have a 2001 Honda rancher ES 350 and i recently just tightened the front brakes on it and after i did that the steering got hard to turn it was fine till i did that and i put new bearings on the front left plz help but yea steering was fine till i tightened the brakes up and put new front left bearings on it
Old Apr 19, 2009 | 05:57 PM
wheily's Avatar
i would loosen them up see if they are a little to tight
Old Apr 19, 2009 | 06:14 PM
rancher5's Avatar
Default Reply
i would but idk if that would help cause you jack it up and it's still tight should it still be tight when its jacked up. To make sure i tightened up right one it is the one where its on the master cylinder looks like small gear right?
Old Dec 2, 2010 | 09:16 PM
Foreman 450 SS's Avatar
I have a 2004 foreman 450 ES and recently snapped the steering shaft. I tore it all apart and installed a new steering shaft and soon upon doing so i have notices a decent amount of play in my steering. Is there a possibility that the splines on the steering shaft are sheared off inside the steering box or could it be a bearing within the steering box? If you could get back to me that would be awesome!
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
