help!!! no spark
Old Jun 6, 2009 | 10:05 PM
1fastford's Avatar
Default help!!! no spark
hey i got a honda 200 atc and its geting no spark out of the coil,it is geting 12-14volts going in but nothin going out?
i have changed out the coil, cdi, brainbox, sparkplugs, and checked my wires
can any one pleace help me
Old Jun 7, 2009 | 05:31 AM
HondaMechanic's Avatar
Have you tested everything , what year & model ...
Old Jun 7, 2009 | 10:45 AM
1fastford's Avatar
1984 honda bigred 200es
yes ive tryed every thing
Old Jun 8, 2009 | 05:57 AM
I would check the inhibitor relay ... Honda doesn't include this test with the ATC200ES you have to use the TRX200 Foretrax manual ... here are the ATC200ES tests and the inhibitor tests ..
Old Jun 8, 2009 | 03:26 PM
1fastford's Avatar
i checked the coil that passed,checked my old and new pulse gen,old one was at 30 and the new was at 90om.?
i dont know how to check the relay? i dont know where its at?
Old Jun 27, 2009 | 07:48 PM
1fastford's Avatar
any one? help!
Old Jul 2, 2009 | 08:57 PM
1fastford's Avatar
any one
Old Jul 3, 2009 | 05:48 AM
The coil resistance will be higher if you test it with the cap on ..
Here is a coil test .
If everything tests good I would check the inhibitor switch (relay) it will be inside a rubber boot , I can't remember just where it is but it will be handy the battery ..
Old Jul 5, 2009 | 11:13 PM
1fastford's Avatar
this? it dont look like the pic but i think this is it..where can i buy a new one?i looked at honda page and they have one but it dont look like this????????????????????????????
Old Jul 5, 2009 | 11:34 PM
1fastford's Avatar
,don't that old trick if u put it in the freezer for like 15 mins it could fix it?
it worked on other things idk just a thought..
im going to order one from ebay.
you think a new Regulator will help my spark problem??
