300ex rear hub question.
Old Jul 13, 2009 | 10:21 AM
snowmonh's Avatar
Question 300ex rear hub question.
Hi Guys,
Was wondering if anyone could explain how I can identify weather I need new hubs or a new axle. IE tons of play in the rear wheels. Removed the rear wheels and inspected the hub spline and axel connection and I can't tell which is wore.
The carrier bearing looks perfect. No play
Between the hub and axel there is tons of play.
So do I need a axel and hubs or just the hubs. Was thinking just the hubs..
Or can I just tighten the hell out of the hub bolt?
Tim
Old Jul 13, 2009 | 11:41 AM
budedm's Avatar
Ok, I'll assume you are correct when you say the bearings are fine. The hub can be tightened but if the splines are worn, no amount of tightening will help. Plus, it should only be tightened until it bottoms out on the shoulder that is on the axle, and then until you can get the pin in. I would think that since the hub is softer than the axle, the hub will wear first and that is your problem. Do you know a friend that has a newer 300ex? You could swap yours out and see if that's the problem.
Old Jul 13, 2009 | 12:16 PM
snowmonh's Avatar
Yep, yep.. My thoughts exactly.. My son has a 300ex and I thought about swapping but wasn't sure about them being the same part number. Thanks a million. Tim
Old Jul 13, 2009 | 02:51 PM
no1's Avatar
no1
I just repaced my rear hub a few weeks ago. Got one off ebay for 20 bucks. I have found out that many of the 300ex parts throughout the years are interchangeable. My ex is a 01 and the replacement hub was off a 96.
Old Sep 26, 2010 | 05:48 PM
Honda 300ex's Avatar
I have a 2000 300 ex and the hubs started coming loose every 2 days so i recently bought new hubs and a good axle and after a good amount of riding they get really loose i have tried everything i can think of can anyone help Please!!!
Bigtwin700
Sep 9, 2015 09:32 AM
Wiley wolf
Sep 7, 2015 08:32 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
