stripped bolt on sons '86 trx200sx
Old Jul 15, 2009 | 09:09 PM
peacemon66's Avatar
Default stripped bolt on sons '86 trx200sx
i was wondering if anyone could give me advise on how to attack this problem. the bolt that holds the chain tensioner adjuster is stripped out. its a 17mm bolt that screws directly into a part of the brake assembly. it looks like name of the part on the microfishe is called the holder. and it lists for $185. my question is should i try to rethread it with a tap and die.....or is there a better way to fix it.
Old Jul 16, 2009 | 05:11 AM
HondaMechanic's Avatar
I believe those are actually nuts that are spot/heat welded on the inside .. You could use a heli-coil but it would have to be partially dis-assembled (to get a straight crack at it) so I think I would cut/grind the old nut off and weld a new nut on ..
Here are the 4 chain adjusting bolts ..
kampswas
Sep 23, 2015 05:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
