2007 Rincon
Old Jul 17, 2009 | 04:51 AM
Cummins123's Avatar
Default 2007 Rincon
I am looking for the fuel injection diagram, for the 07 Rincon. I am trying to trace fuel lines.
Old Jul 18, 2009 | 11:57 PM
Jawsh's Avatar
I sent you a PM with a link that might help you.
Old Jul 19, 2009 | 05:36 AM
HondaMechanic's Avatar
Whay are you tracing fuel lines..
Old Jul 20, 2009 | 06:10 AM
Cummins123's Avatar
Default 2007 Rincon
I am getting a hissing noise and a small amount of fuel from the gas cap out the vent tube.
Old Jul 20, 2009 | 08:25 AM
Jawsh's Avatar
Hmm, I've heard of numerous reasons this can be happening on many different ATVs. It could be a venting issue, meaning that the breather hose could be getting pinched somewhere. I had a problem like that with my Foreman but it would vapor lock it, so I trimmed my breather hose by about 6 inches so it goes in just enough. As for the small amount of gas comming out of the breather hose, you could be filling the tank too full and causing it to get into the breather hose, I've heard of that happening too. Hope it helps.
Old Jul 20, 2009 | 09:33 AM
JeffinTD's Avatar
Mine typically makes a perculating noise.
Tank of fuel on top of hot engine, getting shaken around gives off quite a bit of vapors.
Make sure the vent tube isn't kinked, but if it runs fine and doesn't give a big woosh when you open the fuel cap, I wouldn't worry about it.
If it bothers you, try a new gas cap.
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
