***trx 250x help***
Old Jul 31, 2009 | 04:39 PM
hondarider288's Avatar
Question ***trx 250x help***
i have a 1987 trx 250x.
when i finally kick it enough to get it to turn over (takes a while) it just wants to put around and backfire. full throttle putts around the yard at about 4 mph, cant even get it out of first gear.. does not idle on its own anymore either. i cleaned the jets out on the carb and it didnt seem to do anything. i also changed the gas a few times to see if it was due to bad gas, helped none.. if you know whats wrong please message me with your help... thanx
Old Jul 31, 2009 | 04:46 PM
91Warrior357's Avatar
check to see what kinda spark that thing is putting out, kinda seems like a funked up carb problem that needs thoroughly cleaned.
Old Jul 31, 2009 | 06:23 PM
right when the problem occured i got a new spark plug first thing, so it has a brand new plug in it.. i may just rebuild the carb,
Old Aug 2, 2009 | 06:57 PM
honda44663's Avatar
Check the float in your carb i had one that the float had a pin hole in it and it was doing the same thing
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
