oil change
Old Jan 13, 2010 | 07:10 PM
snow45's Avatar
Default oil change
i have a 2001 honda 400 foreman 4x4 i would like to know how to do a oil change
Old Jan 14, 2010 | 08:10 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Drain bolt is on the bottom of the engine. Oil filter should be similar to this, and be sure you don't put it in backward: Honda 400EX ATV Oil Change Insturctions - ATV Technical Articles
I fill it to the top of the dipstick, then take it for a very short ride and check the oil level again. Use a motorcycle specific oil that is rated API SG/JASO MA. I recommend Maxima Premium or Extra if you want to go synthetic.
If you have to ask about oil changes....I bet you have never adjusted the valves or changed the oil in the differentials either....
Old Jan 15, 2010 | 09:33 AM
JeffinTD's Avatar
As noted above, do not put the filter in backwards. Doing so will block all oil flow.
Also, do not overtorque the drain plug.
Old Jan 15, 2010 | 10:08 PM
Helmut1's Avatar
Yeah, like reconranger and JeffinTD said, make sure you don't put it in backwards. I have seen this done and it will definitely damage your engine.
Old Jan 16, 2010 | 05:39 AM
HondaMechanic's Avatar
The newer Honda oil filters won't go in backwards , they have a lip around them that only allows them to go in 1 way .. You have to be careful with aftermarket filters which will go in either way ..
Old Feb 3, 2010 | 08:01 PM
digger55's Avatar
always use honda gn4 oil
Old Feb 8, 2010 | 01:31 PM
Specta's Avatar
And always install new Honda aluminum drain plug gaskets.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
