1984 big red 200ES
Old Feb 15, 2010 | 02:28 PM
oldbigred's Avatar
Default 1984 big red 200ES
hi guys i have 84 honda big red 200ES.the trans is stuck in gear.I have tried to put it in netrual.it wont move.any ideas?
Old Feb 15, 2010 | 04:21 PM
honkaw's Avatar
I hate to ask this but have you tryed rocking back and forth while trying to get it out of gear?
Old Feb 15, 2010 | 08:46 PM
KNOWSALOT's Avatar
The Facility
Be sure the Forward/Reverse selector is completely engaged into Forward. It will sometimes kick out without appearing it has.
If that's not the issue, it's internally and there's a laundry list of what "could be" wrongs that isn't going to help much into you get in there.
You will want to inspect the sub tranny first and then on to the main one, which requires an entire splitting of the cases on that model.
Old Mar 16, 2010 | 02:48 AM
drjoe171's Avatar
Default stuck in gear?
I just had to beat/soak/pry mine apart. brakes were stuck to the drum and I thought the gearbox had locked up...and I used to build transmissions for a living Definitely time for a new hobby
Old Mar 17, 2010 | 10:53 AM
farrier403's Avatar
My G/F has a 82 200 Honda that was stuck in gear. There is a a nut with a threaded rod on the right side of the engine. I loosened the nut and turned the rod half a turn and voila!! The old girl shifts again...
Old Mar 17, 2010 | 08:14 PM
posty2100's Avatar
heres a link to the manual, start taking it apart and you will most likely find the problem
ATC Manuals
oldschool64
Aug 12, 2015 07:13 AM
timster911
Jul 13, 2015 01:57 PM
bigmanMH
Mar 2, 2000 02:57 PM
