250x 400ex swingarm
Old Feb 26, 2010 | 07:15 PM
oldskool87's Avatar
Default 250x 400ex swingarm
i was wondering what is required as far as modification to put a 400ex swingarm on my 250x frame
Old Mar 2, 2010 | 12:19 AM
KNOWSALOT's Avatar
The Facility
Unless you have the entire rearend of the 400EX, this swap is not cost effective for what small gain you would get. Major machining is required along with welding linkage mounts. These kinds of mods to 250X and 300EX quads usually only go down when using 450R parts,..not 400EX.
You would be better off in the pocketbook in the long run by finding an aftermarket swingarm that directly replaces yours.
Old Mar 3, 2010 | 11:06 AM
oldskool87's Avatar
what about a 250r rear swap i want to gain about 2"in the swingarm
Old Mar 3, 2010 | 02:31 PM
KNOWSALOT's Avatar
The Facility
Same thing with the 250R,..it requires major fab work and welding on the frame.
There is no bolton swap for a 250X/300EX swingarm.
The old 350X swingarms are the only thing that come close to being a direct fit but they require alot of work to install to. Lots of spacers and bushings need to be made, along with a brake hub swap, and having to use the 350X shock, etc,etc. It's hardly a bolt on and ride project. They are about 1 1/2" longer than the 300EX/250X swingarms.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
