Help!!!! My 300ex won't run
Old Feb 9, 2016 | 02:43 AM
Try a new plug. While you have the plug out, do a compression test, if you don't have a tester, check if it blows your thumb off the plug hole when you spin the engine over on the starter. If it does, you probably have a fuel problem, you are not getting the right amount of fuel. Clean the carb out. If compression is low, re-set the valve clearances.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
