2000 Honda Rancher electronic shift - Help!!
Old Apr 6, 2010 | 10:48 PM
tsotsi's Avatar
Default 2000 Honda Rancher electronic shift - Help!!
So last fall I rolled the Rancher off the side of a mountain. All in all it fared pretty well. With an bit of bending and straightening I was able to ride it out, flat tire and all. Besides the bent racks and handlebars the only thing lost was the crushed speedometer/meter. Once I put a new wheel on I was able to ride it no problems. Over winter I put all the replacement parts on. Fired it up for the first time today and took it for a run. It was great for about 2-3 minutes and then there was no response from the shift buttons. I bought the speedometer used the guy said it was off a 2002. It all plugged in, the neutral and reverse lights work but there is no gear position being indicated on the screen and the speed stays at 0. If I shut it off and restart it will shift but then after a while nothing. All suggestions are appreciated.
Thanks
Old Oct 9, 2010 | 09:02 PM
The man for the job!!!'s Avatar
call 601-659-9931 i promise you he can help you . He sells a bolt on hand and foot shifter for the Honda ES models.
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
