TRX250EX noise
Old Jul 17, 2010 | 07:33 AM
crcmech's Avatar
Default TRX250EX noise
Hi,I have an 06 trx250ex with the sport clutch and shaft drive. It started making a noise yesterday and I have no idea what it could be. It sounds like a whine and increases as you give it gas. I can also hear a lite rattle. The noise is there from idle through all gears. There is no power loss and it shifts smooth. It does not smoke... any ideas where i should look? sounds like its comin from the top end somewhere,is there no cam chain tensioner? thank you!
Old Jul 17, 2010 | 10:13 PM
crcmech's Avatar
I've been thinkin,could it be the one way starter clutch or needle bearing going bad?
Old Jul 18, 2010 | 04:24 AM
crcmech's Avatar
I have an audio clip if somebody thinks they can help...
Old Mar 23, 2012 | 12:34 PM
GoldHEMI's Avatar
Did you ever gigure out what was causing the noise? I have one and its making a similar noise, sounds like gear whine.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
