02 400ex wont start?
Old Jul 21, 2010 | 12:22 PM
mikesbikesmalden's Avatar
Default 02 400ex wont start?
it turns over and just kinda pops sounds like it wants to start but it wont. installed new stator redone carburetor checked flywheel key checked timing checked compression all is fine. starting fluid does nothing either changed plug and gas twice nothing helps got any ideal
Old Jul 21, 2010 | 05:02 PM
2006dvx400's Avatar
sounds like a bad valve.
Old Jul 21, 2010 | 07:58 PM
i pulled the top off and bored cylinder 0.40 over and installed all four valves. here is what it dont was riding down a gravel county road and a cop pulled me over i turned it off and it would not start back. ran great when shut off?
Old Jul 21, 2010 | 08:24 PM
zach0199's Avatar
did you check your fuses and all electrical connections.
Old Jul 21, 2010 | 09:01 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Did you recheck timing after you turn it off? cam chain tensioner could have slipped when engine stopped. causing cam chain to jump an tooth... also is your starter clutch slipping and not turning engine fast enuff... try pushing off in second gear an see if its starts! BUT don,t pull off....Good Luck...
Old Jul 22, 2010 | 09:28 AM
its in time. it turns over fast its making a noise thats hard to explain but it hits every other rotation we pulled every plug in off and cleaned checked the fuse timing chain is tight acts like a electrical problem but we changed the cdi and coil and stator
Old Jul 22, 2010 | 08:56 PM
Loved
Community Favorite
I guess I would make another ground like use an jumper cable[use one side] black side to engine and other black to frame to see if harness ground or frame is cracked making an incomplete grond... Can you put an timing light on and look at electical timing to see if its advances..... Also did you replace spark plug? Good Luck.
Old Jul 23, 2010 | 03:45 AM
williams8899's Avatar
You can take the spark plug out and put your finger over the hole. It should have at least enough compression to blow your finger off the whole and make a loud pop, this is how i found out my bike didn't have enough compression. I would still use a compression checker though if you have one. If not you could have a burnt/stuck valve or one that isn't seated well and losing compression.
Electronic Cigarette
E Cigarette
Old Jul 23, 2010 | 06:50 PM
im a atv mechanic and i have a atv mechanic togeather we have over 15 years exp it has so much compression it will allmost feel like it burns your finger if you try to hold it over the plug hole. chnaged plugs 5 times its not the ground its not the carburetor its 1005 in time and we have been thru the engine top end all new it has us stumped to say the least.
Old Jul 23, 2010 | 09:19 PM
Loved
Community Favorite
Did you do an leak down test? Will it crank if you push it off??
